laserlock problems
First post, by Yazzum
Does anyone know a way of getting championship manager 2 96/97 working?
i'm getting the laserlock problem. The disc is legal. I've changed the DOS4GW file from advise from another forum but that hasn't worked.
Reply 1 of 4, by wd
Rank DOSBox Author
DOSBox Author
I doubt this will go through the OS layer. Anyways try with -ioctl and
specify the label, though not too much hope.
Reply 2 of 4, by Yazzum
I'm new to using dosbox so i have to say i don't understand the method to what you've posted, could you simplify the language a bit please?
Reply 3 of 4, by wd
Rank DOSBox Author
DOSBox Author
Try mounting the cdrom with something like "mount d e:\ -t cdrom -ioctl"
if e:\ is your real cdrom drive. Then fully reinstall the game, and for
running the game use the exact same mounting.
Reply 4 of 4, by Yazzum
Just tried that and it doesn't work. Thanks for the help though, looks like i won't be able to play this one.
