Help with Dreamweb?
First post, by mtxcoll
Hi, I'm trying to use Dreamweb in Dosbox. I'm using the Abandonia version. When I start dreamweb.exe, I hear music/sound but the screen stays black. I checked my dosbox.conf file:
[sdl]
fullscreen=false
fulldouble=false
fullresolution=original
windowresolution=original
output=opengl
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
usescancodes=true
[dosbox]
language=
machine=vga
captures=capture
memsize=16
[render]
frameskip=0
aspect=false
scaler=normal2x
I'm running Windows XP Home Edition SP2 with an AMD Athlon 64 processor, 2 GB ram, and Nvidia Geforce 6600 GT. I've searched the forums here and it seems like noone else has this problem; could it be an issue with the version of Dreamweb I have?
Reply 1 of 11, by MiniMax
Rank Moderator
Moderator
I don't know if it helps, but try playing with the different output=......... settings.
_________________
Reply 2 of 11, by Freddo
Possible. I played thru Dreamweb in DOSBox with no problem. But then again, I played it from the CD I bought.
Reply 3 of 11, by catchaserguns
You should use the forums from where you got the game. We don't answer questions on abandonware or give support to abandonware on this forum.
Reply 4 of 11, by ADDiCT
Or, in the case of catchaserguns, we don't answer questions at all, but find great joy and deep fulfillment in telling anyone that wants to hear it (or doesn't - makes no difference), that Abandonware related questions are not welcome on VOGONS. (; As i am not a part of the collective that catchaserguns refers to as "we" (whatever that may be), i can try to help you a bit.
The game works fine with DOSBox v0.70. As MiniMax suggested, you should try different "ouput" settings. It would probably also be wise to test if other games do work.
Reply 5 of 11, by mtxcoll
Thanks for the prompt assistance! I tried the different "output" settings to no avail, but I realized that I was using Dosbox v.0.71 so I installed the 0.70 version instead and it worked! 😎
Reply 6 of 11, by ADDiCT
Uh-Oh... You're right, i get a black screen with 0.71, too.
Reply 8 of 11, by ADDiCT
Jup, that's why i was "Uh-Oh"-ing. (; I didn't have much time to test 0.71 until now - did a few games now, but so far, Dreamweb is the only one with a black screen.
Reply 9 of 11, by SysGOD
ADDiCT wrote:
Or, in the case of catchaserguns, we don't answer questions at all, but find great joy and deep fulfillment in telling anyone that wants to hear it (or doesn't - makes no difference), that Abandonware related questions are not welcome on VOGONS. (; As i am not a part of the collective that catchaserguns refers to as "we" (whatever that may be)...
there's no need to criticize him for that. there enough of threads on this forum where people asking for help with downloaded/ripped games or problems (files missing, no sound...) that are not related to dosbox.
on topic:
black screen with the german cd version on 0.71 for me too.
Reply 10 of 11, by ADDiCT
SysGOD: have a look at the guy's other posts, and you'll maybe understand my sarcasm. What's _really_ funny is the fact that we've identified a possible DOSBox bug, which wouldn't have happened if we didn't try to help the original poster. (;
Reply 11 of 11, by wd
Rank DOSBox Author
DOSBox Author
It is a bug (well black visible palette at least seems to be one).
Fix one, break another.....
