First post, by Guyper
After having installed the game, I launched it by typing dragon.bat and I got this message
Error "-32" in module "5" data: 0 0
Most recent memory check: 466512
Most recent DOS error: 2
Stack use indicator: 10075
But in the setup menu, it showed that I had enough dos memory and ems to play the game though.
Please help, thanks
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
do you have the cdrom mounted at the right location ?
dos error 2 means file not found.
Water flows down the stream
Reply 2 of 2, by Hazekel
Here is my DOSBOX bat file
"dosbox.exe c:\ADV\DS.BAT -c "mount c c:\ADV" -c "mount D D:\ -t cdrom -usecd 0 -ioctl" -conf C:\Adv\MPSDISC.007\dosbox.conf -fullscreen"
I still get the error message. I have tried just about everything I can think of. CDROM is mounted correctly and the game folder is created within C:\ADV. I thinks that that is the root of Drive C: because it automatically creates the folder MPDISC.007 with no options to place it elsewhere. I also tried without the "-usecd 0 -ioctl" and changed a few settings in the DOSBOX.CONF to no avail.
Thanks
