Full Throttle issue
First post, by Guyper
I'm able to launch the game but a few minutes later the game would crash and the message "DOS/4GW Fatal error" would appear.
Could it be that I have chosen the wrong sound blaster config?
Thank you
Reply 1 of 4, by collector
Just use ScummVM
Reply 2 of 4, by wd
Rank DOSBox Author
DOSBox Author
Or check the sb configuration against what is set in your dosbox.conf
Reply 3 of 4, by Guyper
After I've tried to turn off the EMS, the game seem to crash less but it still does crash from time to time
Reply 4 of 4, by wd
Rank DOSBox Author
DOSBox Author
Did you install it within dosbox? If not, do that.
Else try with sound disabled, and with core=normal.
