I need Help with Flight SIM
First post, by PixelLovesDos
I just got a physical copy of Flight SIM for MS-DOS but I have a windows 10 PC. If anyone can help me try to get this MS-DOS game to run on my pc I would be VERY grateful.
    1.77 MiB
    I got this from goodwill btw
Reply 6 of 25, by Errius
Huh, isn't vDOS for textmode applications?
That appears to be Flight Simulator 5.1 which should work fine on DOSBox. You will need to mount the CD drive in DOSBox, then install it from the disk.
Is this too much voodoo?
Reply 9 of 25, by PixelLovesDos
Kalle wrote on 2023-09-24, 08:10:
That's FS 5.1 and it does work with DOSBox.
What exactly didn't work? How did you try it, what error messages did you get, etc. ?
Every time I open setup it just says this exact thing
    1.11 MiB
    I put “C:\FLIGHTSIM51”
Reply 11 of 25, by Disruptor
leileilol wrote on 2023-09-25, 03:48:
"FLIGHTSIM51" is a long name. DOS does not do names longer than 8 characters
Except volume labels. They can have 8+3 = 11 characters.
But C:\FLIGHTSIM51 won't work.
Reply 13 of 25, by giantclam
PixelLovesDos wrote on 2023-09-24, 22:31:
You've failed to mount a directory to represent C: drive in dosbox .... rtfm =)
Reply 14 of 25, by giantclam
Just to confirm ~ I downloaded the .iso of this title from REMOVED, and was able to install (both from an image mount & burned CD) and run this game with dosbox 0.74-3
Granted I'm using linux, but AFAIK it should work with the windows build of dosbox
Reply 15 of 25, by DosFreak
PixelLovesDos,
Post everthing that you are doing.
More than likely this is an issue with directory name, mounting and confusion on where to install.
giantclam,
Removed name of site to so called "abandonware".
Make your games work offline
Reply 16 of 25, by PixelLovesDos
It’s always after I press of these two buttons, doesn’t matter which one.
    1.68 MiB
    Just to confirm this is Flight Sim 5.1
Reply 17 of 25, by PixelLovesDos
DosFreak wrote on 2023-09-25, 23:44:
PixelLovesDos, […]
PixelLovesDos,
giantclam,
Here’s a video showing what I’m doing: https://youtu.be/T47lR5CsEIk?si=TSB4uu5ZTAk-MB_F
Reply 18 of 25, by giantclam
@DosFreak ~ noted ; will observe etiquette in future posts, thanks
@PixelLovesDos ~ I was able to recreate this error with dosbox in linux -- problem was I didn't have a local dir mounted as C:
https://www.dosbox.com/wiki/MOUNT
Going by your YT vid, that's what you're missing
Reply 19 of 25, by PixelLovesDos
giantclam wrote on 2023-09-26, 02:13:
@DosFreak ~ noted ; will observe etiquette in future posts, thanks […]
Not that’s not it, I was using D: because I’m using a cd-rom. And usually a cd-rom is in D:
    1.43 MiB
    Here’s what’s in the cd-rom if needed.
