Getting the original Police Quest to run
First post, by Stardust
I have a laptop with Windows XP on it and I have installed DOSBox0.72-win32-installer.exe.
😈 I have tried to play Sierra's original Police Quest (not the VGA version), and am having problems with the graphics. The game boots ok, has sound and the game speed is alright, but when it comes to the " dialogue boxs " i.e. the character speaks, the writing is all blurred. Can anyone help ????
When I type a command it, the writing is perfectly ok, i.e. open door, get in car etc etc, but just the " dialogue boxes" are blurred.
Do I need to install an earlier version of Dos Box i.e Version 0.65 ???
I have limited knowledge of computers, so if anyone types instructions for me, please make them as detailed as possible... 😁
Many thanks.
Amy.
Reply 1 of 31, by Qbix
Rank DOSBox Author
DOSBox Author
can you make a screenshot and attach it here ?
(press ctrl-f5 in dosbox and look in c:\program files\dosbox-0.72\capture for the result)
Water flows down the stream
Reply 2 of 31, by Stardust
forgive me, I need very detailed instructions !!!!!!!!!! I opened the game and pressed the PRT Screen button, at the appropriate moment.... and then exited to Windows Explorer and found the Program Files in C directory, with the DosBox Filw and pressed Ctrl F5 and then opened the capture file. But nothing was there.
What am I doing wrong ?
Cheers.
Amy.
Reply 3 of 31, by MiniMax
Rank Moderator
Moderator
You don't press PtrScr. You run DOSBox, your press CTRL-F5 and DOSBox will save a screen shoot in the capture folder.
_________________
Reply 4 of 31, by Kippesoep
No, don't press Print Screen, that's a Windows function (copy screen to clipboard), press Ctrl-F5 instead. This activates DOSBox' own screenshot function (which saves a PNG to the capture folder).
My site: Ramblings on mostly tech stuff.
Reply 5 of 31, by avatar_58
What video driver is the game using? If you run install I mean. Is it using the 16 color vga one? It sounds almost like it's hercules or something else.
Reply 6 of 31, by Kippesoep
The original PQ doesn't have an install program to select the video driver. There was a known problem with stuff like this occurring on MCGA cards, though I've never seen it happen in DOSBox.
Reply 7 of 31, by avatar_58
Well I'm brainstorming at work with no access to dosbox, you'll have to forgive me. 😉
Reply 9 of 31, by Stardust
I'm still having trouble. I launched DosBox and pressed Ctrl F5. But there was no screenshot in the Capture folder.
I then launched the Police Quest game and tried pressing Ctrl F5 ???
Is this correct ?
How do I actually get a screenshot of the Police Quest game ?
Cheers.
amy.
Reply 10 of 31, by Stardust
I got so irritated with DosBox and the whole screenshot thing, I just took some photos of my own with my camera phone....
So here they are, I've added them as attachments....
cheers.
amy.
Reply 11 of 31, by Stardust
As you can see the writing in the dialogue boxes is all blurred and unreadable....something I can't see to fix...
from amy.
Reply 12 of 31, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Seems unlikely it's a DOSBox issue, since all the AGI games I've tried work OK. Perhaps some part of the game (regarding fonts) is corrupt.
Paul David Doherty made a utility program which identifies most versions of the AGI interpreter software and game data:
http://pdd.if-legends.org/sierra/aginfo.zip
Unzip it into the game directory and run it. AGInfo should show the interpreter and data version numbers and whether they are "known" (i.e. in its database). What it has to say may indicate if your files are corrupt.
Reply 13 of 31, by collector
This is a very common problem with AGI games played on modern graphics cards. That utility will only look for the file "AGI" and not any of the data files. The AGI version will not make any difference. This does not happen with DOSBox. He must be playing with the NTVDM, not DOSBox. ScummVM will solve his issue.
Reply 14 of 31, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Hmm, my first reaction is not to assume someone is so lost that they're using the WinXP command shell thinking that it's DOSBox... 😵
AGInfo reports BOTH the interpreter (AGI file) version number, and the data file version number... I think it uses the first VOL file to identify the data. AGInfo is still useful to identify the game data version even if you don't have the interpreter files (which aren't needed with ScummVM).
Reply 15 of 31, by MiniMax
Rank Moderator
Moderator
Moved to the DOS forum since user is not using DOSBox!
_________________
Reply 16 of 31, by FranMichaels
Hi there.
Okay for you to run police quest 1 in DOSbox, go the folder of the game, and right click START.EXE and choose Open With DOSBox (this works under Linux, auto mounts etc, should work in Windows I guess?)
If all goes well you'll be all set.
Other option, try scummvm.
http://www.scummvm.org/
Just launch it, then click Add game, choose the folder with Police Quest 1, and you are good to go.
Screenshot below, running pq1 in each app (just for demonstration purposes 😉)
Q: What's tiny and yellow and very, very, dangerous?
A: A canary with the super-user password.
Reply 17 of 31, by eL_PuSHeR
[Moved]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 18 of 31, by Stardust
User is using DOSBOX...just not sure how to use it yet, finding my way around...kindly move my post back...thankyou.
Reply 19 of 31, by collector
This does not work in Windows with out installing the "DOSBlaster" frontend or adding a registry entry. What does work in Windows without any changes to the OS is simple Drag and Drop.
@ Stardust - If you just double click on the executable, SIERRA.COM, it will not use DOSBox. it will use the NTVDM and garble the text. Just put a shortcut to dosbox.exe on your desktop and drag and drop SIERRA.COM onto that shortcut. That will automatically mount the game's folder as your "C:" drive and start the game. Otherwise use ScummVM
