CDROM / MSCDEX Error
First post, by cronodevir
...well, the program i am trying to run...doesn't require a cdrom/floppy drive in the first place. [i don't even have a floppy drive] I am running it off my computer. The program runs fine by itself - but with no sound.
I am trying to run Secret of Monkey Island 1.
I mounted Drive D anyways, and install MSCDEX...and it still gave me the error.
Reply 1 of 6, by wd
Rank DOSBox Author
DOSBox Author
How do you install mscdex? How does your mounting look like?
Reply 2 of 6, by cronodevir
I just did the command listed in the FAQ
mount d d:/ ....and then it said MSCDEX installed...so then i closed out, and i dragged the game.exe onto dosbos.exe and it laoded then gave me the error.
Reply 3 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
you need to do it in the same session. So no closing and then dragging
Water flows down the stream
Reply 4 of 6, by MiniMax
Rank Moderator
Moderator
60 Seconds Guide to DOSBox.
_________________
Reply 5 of 6, by cronodevir
Well,it plays, but no sound, and a tiny window...
Reply 6 of 6, by MiniMax
Rank Moderator
Moderator
Line 93-98 in the README file. You did read the Read Me, didn't you?
_________________
