First post, by kicker04
Hi!
I got some problems with Gabriel Knight 2. If i try to save the game crashes and this message appears:
Error 47: Not an object: $fe
..\asm2cpp.cpp(55)
Script 64917(30)
C:\SIERRA>
Please help me!
Reply 3 of 17, by MiniMax
Rank Moderator
Moderator
60 Seconds Guide to DOSBox.
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
_________________
Reply 4 of 17, by kicker04
I read that guide. I did it this way:
keyb de
mount d /volumes/volume_id -t cdrom -ioctl
mount c /dos-spiele
c:
cd sierra
cd gk2dos
gk2dos
Then the game start. It seems to run fine, exept for those save/load problems. I didn't configure anything else.
Thanks for help
Reply 6 of 17, by MiniMax
Rank Moderator
Moderator
Hmmm... It looks okay, but shouldn't there be some kind of installation first? Where you do a
D:
install
before running the game?
_________________
Reply 7 of 17, by kicker04
I installed it this way:
keyb de
mount c /dos-spiele
d:
install.exe
That was all. The strange thing is that at the beginning I had no problems to save. Then one time the game crashed while I clicked on "load" during game play. Now I can load a saved game state, but if I click on save the game exits and this error message I wrote appears. I don't understand that.
Reply 8 of 17, by MiniMax
Rank Moderator
Moderator
AHHH! Some file, or information in a file, must have been damaged during that crash. Does the problem happen if you start without loading an existing game state, and then save as a new game state?
_________________
Reply 11 of 17, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
It's an error from the game not from Dosbox.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 13 of 17, by MiniMax
Rank Moderator
Moderator
scanlines??
Have you selected some non-default scaler in DOSBox?
_________________
Reply 17 of 17, by dougdahl
If by "scanlines", you mean interlaced, then that is the way that GK2 played the movies.
Never heard why, but I've presumed it was a limitation of the technologies used then, or in a effort to reduce the size of the MANY videos in the game.
I'm not bothered by them, but apparently there is a patch at a website that will remove those lines.
Never used it so no idea if it works, how well, or whether it is just for the windows version.
It's at
https://gkpatches.vogons.org/
under "Gabriel Knight 2 Interlace Patch"
