First post, by alf717
Hello everyone,
I'm using Gulikoza's latest build of DOSBox with Glide support and am having a few issues with Glide.
My first is with resolution. No matter what I set the full screen resolution to the game will always default to 640x480 in full screen mode.
Next up is clipping issues. I took a few screen shots that I uploaded for the Tomb Raider Chronicles forum:
http://img359.imageshack.us/my.php?image=dosb … 21043335bs4.png
http://img370.imageshack.us/my.php?image=dosb … 21125361iw9.png
I installed the game using DOSBox and I am using the Voodoo Rush patch for Glide support. My Tomb.exe file is 853KB in size. My setup is Vista Business x64 with all the latest patches including SP1 and an ATI 3870 with the 8.3 drivers. I followed a set of instruction that I found from a user named gidierre over at the Tomb Raider Chronicles forums to setup DOSBox with Glide support.
http://www.tombraiderforums.com/showthread.php?t=111264
DOSBox Configuration:
# This is the configurationfile for DOSBox 0.72.
# Lines starting with a # are commentlines.
# They are used to (briefly) document the effect of each option.
[sdl]
# fullscreen -- Start dosbox directly in fullscreen.
# fulldouble -- Use double buffering in fullscreen.
# fullresolution -- What resolution to use for fullscreen: original or fixed size (e.g. 1024x768).
# windowresolution -- Scale the window to this size IF the output device supports hardware scaling.
# output -- What to use for output: surface,overlay,opengl,openglnb,openglhq,ddraw,dir ect3d.
# autolock -- Mouse will automatically lock, if you click on the screen.
# sensitiviy -- Mouse sensitivity.
# waitonerror -- Wait before closing the console if dosbox has an error.
# priority -- Priority levels for dosbox: lowest,lower,normal,higher,highest,pause (when not focussed).
# Second entry behind the comma is for when dosbox is not focused/minimized.
# mapperfile -- File used to load/save the key/event mappings from.
# pixelshader -- Pixelshader program to use for resizing (works with output=direct3d only):
# none,point.fx,bilinear.fx,scale2x.fx,2xsai.fx.
# (or any other .fx file that is available in the Shaders subdirectory).
# usescancodes -- Avoid usage of symkeys, might not work on all operating systems.
fullscreen=false
fulldouble=false
fullresolution=0x0
windowresolution=1776x1000
output=direct3d
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
pixelshader=none
usescancodes=false
[dosbox]
# language -- Select another language file.
# memsize -- Amount of memory DOSBox has in megabytes.
# machine -- The type of machine tries to emulate:hercules,cga,tandy,pcjr,vga.
# captures -- Directory where things like wave,midi,screenshot get captured.
language=
machine=vga
captures=capture
memsize=16
[render]
# frameskip -- How many frames DOSBox skips before drawing one.
# aspect -- Do aspect correction, if your output method doesn't support scaling this can slow things down!.
# scaler -- Scaler used to enlarge/enhance low resolution modes.
# Supported are none,normal2x,normal3x,advmame2x,advmame3x,hq2x,hq 3x,
# 2xsai,super2xsai,supereagle,advinterp2x,advinterp3 x,
# tv2x,tv3x,rgb2x,rgb3x,scan2x,scan3x.
# If forced is appended (like scaler=hq2x forced), the scaler will be used
# even if the result might not be desired.
# Hardware modes (all except surface) also support hardware2x or hardware3x, use for hardware scaling.
frameskip=0
aspect=false
scaler=normal2x
…Show last 186 lines
[cpu]
# core -- CPU Core used in emulation: normal,simple,dynamic,auto.
# auto switches from normal to dynamic if appropriate.
# cycles -- Amount of instructions DOSBox tries to emulate each millisecond.
# Setting this value too high results in sound dropouts and lags.
# You can also let DOSBox guess the correct value by setting it to max.
# The default setting (auto) switches to max if appropriate.
# cycleup -- Amount of cycles to increase/decrease with keycombo.
# cycledown Setting it lower than 100 will be a percentage.
core=auto
cycles=auto
cycleup=500
cycledown=20
[vga]
# svgachipset -- Select one of the following supported SVGA chipsets:
# s3 (default), et4000, et4000new, et3000, pvga1a, or none.
# Full chipset name (like 'Tseng ET4000') will also work
# as long as it contains one of the strings above.
# videoram -- Amount of video memory on emulated SVGA. Not all emulated
# chipsets support this setting.
svgachipset=s3
videoram=2048
[mixer]
# nosound -- Enable silent mode, sound is still emulated though.
# rate -- Mixer sample rate, setting any devices higher than this will
# probably lower their sound quality.
# blocksize -- Mixer block size, larger blocks might help sound stuttering
# but sound will also be more lagged.
# prebuffer -- How many milliseconds of data to keep on top of the blocksize.
nosound=false
rate=22050
blocksize=2048
prebuffer=10
[midi]
# mpu401 -- Type of MPU-401 to emulate: none, uart or intelligent.
# device -- Device that will receive the MIDI data from MPU-401.
# This can be default,alsa,oss,win32,coreaudio,mt32,none.
# mt32rate -- Sample rate of MT32 emulation
# config -- Special configuration options for the device. In Windows put
# the id of the device you want to use. See README for details.
mpu401=uart
device=default
mt32rate=22050
config=
[sblaster]
# sbtype -- Type of sblaster to emulate:none,sb1,sb2,sbpro1,sbpro2,sb16.
# sbbase,irq,dma,hdma -- The IO/IRQ/DMA/High DMA address of the soundblaster.
# mixer -- Allow the soundblaster mixer to modify the DOSBox mixer.
# oplmode -- Type of OPL emulation: auto,cms,opl2,dualopl2,opl3,hardware.
# On auto the mode is determined by sblaster type.
# All OPL modes are 'Adlib', except for CMS.
# oplrate -- Sample rate of OPL music emulation.
# hardwarebase -- base address of the real hardware soundblaster:
# 210,220,230,240,250,260,280
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=22050
hardwarebase=220
[gus]
# gus -- Enable the Gravis Ultrasound emulation.
# gusbase,irq1,irq2,dma1,dma2 -- The IO/IRQ/DMA addresses of the
# Gravis Ultrasound. (Same IRQ's and DMA's are OK.)
# gusrate -- Sample rate of Ultrasound emulation.
# ultradir -- Path to Ultrasound directory. In this directory
# there should be a MIDI directory that contains
# the patch files for GUS playback. Patch sets used
# with Timidity should work fine.
gus=false
gusrate=22050
gusbase=240
irq1=5
irq2=5
dma1=3
dma2=3
ultradir=C:\ULTRASND
[speaker]
# pcspeaker -- Enable PC-Speaker emulation.
# pcrate -- Sample rate of the PC-Speaker sound generation.
# tandy -- Enable Tandy Sound System emulation (off,on,auto).
# For auto Tandysound emulation is present only if machine is set to tandy.
# tandyrate -- Sample rate of the Tandy 3-Voice generation.
# disney -- Enable Disney Sound Source emulation. Covox Voice Master and Speech Thing compatible.
pcspeaker=true
pcrate=22050
tandy=auto
tandyrate=22050
disney=false
[joystick]
# joysticktype -- Type of joystick to emulate: auto (default), none,
# 2axis (supports two joysticks,
# 4axis (supports one joystick, first joystick used),
# 4axis_2 (supports one joystick, second joystick used),
# fcs (Thrustmaster), ch (CH Flightstick).
# none disables joystick emulation.
# auto chooses emulation depending on real joystick(s).
# timed -- enable timed intervals for axis. (false is old style behaviour).
# autofire -- continuously fires as long as you keep the button pressed.
# swap34 -- swap the 3rd and the 4th axis. can be useful for certain joysticks.
# buttonwrap -- enable button wrapping at the number of emulated buttons.
joysticktype=auto
timed=true
autofire=false
swap34=false
buttonwrap=true
[serial]
# serial1-4 -- set type of device connected to com port.
# Can be disabled, dummy, modem, nullmodem, directserial.
# Additional parameters must be in the same line in the form of
# parameter:value. Parameter for all types is irq.
# for directserial: realport (required), rxdelay (optional).
# for modem: listenport (optional).
# for nullmodem: server, rxdelay, txdelay, telnet, usedtr,
# transparent, port, inhsocket (all optional).
# Example: serial1=modem listenport:5000
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[parallel]
# parallel1-3 -- set type of device connected to lpt port.
# Can be reallpt (win32 only)
# parameter:value.
# for directlpt: realaddress (the base address of your real parallel port).
# Can be 378, 278 or 3BC. The first two can be ECP ports.
# Default: 378
# You have to install the PortTalk driver from
# http://www.beyondlogic.org/porttalk/porttalk.htm first.
parallel1=disabled
parallel2=disabled
parallel3=disabled
[glide]
# glide - Enable glide emulation: true,false.
glide=true
[dos]
# xms -- Enable XMS support.
# ems -- Enable EMS support.
# umb -- Enable UMB support.
# keyboardlayout -- Language code of the keyboard layout (or none).
xms=true
ems=true
umb=true
[ipx]
# ipx -- Enable ipx over UDP/IP emulation.
ipx=false
[autoexec]
# Lines in this section will be run at startup.
mount X G:\ -t cdrom -noioctl
mount C C:\tombraid
C:
tomb
OpenGLID Configurations:
Configuration File for OpenGLide
Info:
Priority goes from 0(HIGH) to 5(IDLE)
Texture Memory goes from 2 to 32
Frame Buffer Memory goes from 2 to 16
All other fields are boolean with 1(TRUE) and 0(FALSE)
Version=0.09rc9
[Options]
WrapperPriority=2
CreateWindow=0
InitFullScreen=1
EnableMipMaps=1
IgnorePaletteChange=0
Wrap565to5551=1
EnablePrecisionFix=1
EnableMultiTextureEXT=1
EnablePaletteEXT=1
EnableVertexArrayEXT=0
TextureMemorySize=16
FrameBufferMemorySize=8
Reply 1 of 4, by ADDiCT
I'm no expert with the DOSBox GLIDE patch, but i've been playing around with Lara for quite some time now. (;
The clipping errors are "normal", i'd say. DOSBox' GLIDE emulation is not perfect, and "real" 3D graphics was quite new at the time Tomb Raider was released, so i think TR's 3D code is far from perfect, too.
The GLIDE resolution seems to be hard-coded. It has nothing to do with the resolution you have in your dosbox.conf. Setting a higher resolution would be useless anyways - TR's textures/models/etc. are at a very low resolution, so there would be no gain in image quality with a higher resolution setting.
Reply 2 of 4, by Zebius
I have these clippings too, no matter what you change in dosbox.conf they wiil still exist. So ADDiCT is right about it.
Gulikoza once said that changing resolution was not supported by glide patch YET, so maybe there is a little chance he will add it in the future.
Reply 3 of 4, by gulikoza
What...you mean like this? 😉
Unfortunately I have much too little time to finish it, but Moe and I promised to make it work this year 🤣
TR engine errors are common, actually Glide emulation is too perfect some wrappers have workarounds to reduce such problems...
http://www.si-gamer.net/gulikoza
Reply 4 of 4, by alf717
Ooooo that is so pretty! 😀 If you ever need a beta tester I would love to help out! 😁 Very glad to see you guys are working on a solution and knowing this makes it worth the wait. If you don't mind me asking with more and more widescreen monitors becoming the norm are there plans to support high resolutions like 16:9 or 16:10 modes? Personally I use 1920x1080.
