First post, by ADLE
Hello there, I am having a hard time trying to run lands of lore on vista.
I am using a laptop.
my main drive is in drive c:
and my cdrom drive is on e:
I have the original cd, and have intalled it into c:\oldgames\lolcd
this is what I did, I tried.
mount e e:\ -t cdrom
e:
cd data
cd hardrive
main.exe
then is says setup
so I setup and once I am done it says: wrtting setup file now. IO error with LANDS.CFG (2)
Cant read the rest but I think I did the whole thing wrong, any suggestions please this things is confusing thanks
Reply 1 of 5, by MiniMax
Rank Moderator
Moderator
Read my 60 Seconds Guide to DOSBox (and don't just read it - follow it too).
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
Note: Based on the the information in your post, you should delete your C:\OldGames\LOLCD folder, create a C:\OldGames\LOL folder, and use the following mount commands:
mount C "C:\OldGames\LOL"
mount D "E:\" -t cdrom
before trying to re-install the game from the CD - and do the install from inside DOSBox.
_________________
Reply 2 of 5, by eL_PuSHeR
[MOVED]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 5, by ADLE
Sorry for putting it in wrong forum.
Minimax, I followed your instructions and it worked
Now that I play the game, it seems a bit sluggish. About a 1-2 second delay when I attack, use spells, click on map ect. Even when I move, anyway to fix this? Thanks again
Reply 4 of 5, by MiniMax
Rank Moderator
Moderator
Before you run the game, enter these 2 commands:
C:\>core dynamic
C:\>cycles max
_________________
Reply 5 of 5, by ADLE
wow, that worked perfectly man. Thanks everyone for all your help!
