First post, by astroboy
Hi all
im having problems running Psychic Detective, I have 5 computers 2x 95, 2x 98 and 1x Xp as im a collector of adventure games and just bought PD and I use my pcs when I can and if not I use dosbox. when I try to install on both 95 and 98 pcs from windows all that happens is it says it is restarting windows and dose just that so I cant install from windows. I had success installing from Xp windows. I tried to install from both 95 and 98 pcs in dos with a bootdisk and a mouse driver installed but at the end on the install it says some sort or error happened and quits. It seems to have installed in dos ok but all 4 pcs have some sort of card problem that im not in the mood to fix at the moment so I want to use dosbox for now on my Xp pc. I like before said it is installed from win xp but wont play without dosbox and in dosbox 0.65 it gets to the first screen and then the second that says "movie loading" and then it gets to the first frame of the "Electronic Arts" movie but freezes with a ticking sound as if it is playing the sound file with the movie but is a split second into it and dosnt go any further. this is the same for dosbox 0.61 as on the dosbox games page it says its compatable with 0.61.
I have tried to modify the dosbox.conf file like the mem size and the "machine" to "vga" and "core" to "full" etc. etc.
Is there a patch for this or dose someone know how to get it running?
Please help!!!
AB
