First post, by Peter Swinkels
I've been playing Quest for Glory IV Shadows of Darkness (cd version) in DosBox 0.72 and suspect that sound effects are not being played. I remember hearing these while playing the game on older computers (which I no longer own/have access to)
I could be mistaken, but shouldn't these sound effects be played:
-Wolves howling when the title screen appears.
-"Magical" sound effects when selecting the magic user while creating a character.
-The door being shattered when the fighter crashes through it. (Also while creating a character.)
-Also there's no sound effect for the thief opening the door. (Also while creating a character.)
-Shouldn't the dark one be roaring in the vision of his rising? Also there's no thunder sound effect.
There are a few more, but I think those mentioned above should get my point accross.
I'm using DosBox's default configuration except for having set the number of CPU cycles at 6600 which should be equal to about 66mhz. I've tried pretty much every available combination of sound and music drivers offered by the game. Also tweaking DosBox's soundcard related settings doesn't help.
I know these sound effects exist in the game, you can find and play them using the SCI Resource Viewer. (http://www.sierrahelp.com/forums/viewtopic.ph … 56&p=4994#p4994)
If you have access to the SCI Resource Viewer, look for these:
131.aud (wolves)
141.aud (door shattering)
142.aud (magic user)
143.aud (thief - peeking from behing the door?)
974.aud (dark one roaring)
975.aud (thunder)
So, am I imagening things or can any one else confirm this?
EDIT:
I forgot to mention that the music is fine (at least for the most part) and I can also hear the narator.
