First post, by MasterO
Dosbox .72 and .73
Thinkpad R40
Intel Pentium M Processor 1.3 GHZ
ATI Mobility Radeon 7500
2 GB RAM
Western Digital 6400AAV External HDD
Win XP SP3
Original Mario is Missing Deluxe! CD
http://i112.photobucket.com/albums/n189/Maste … /dosbox_002.png
Mario is Missing Deluxe requires a CD for the voices and avi videos in the tourist booths, so I mounted it as above from the WD External. I used imgburn to burn it at 6x from the Original Mario is Missing Deluxe CD. The mariom2 folder is where the non-CD files are stored. Mariom.iso is the imgmounted CD.
http://i112.photobucket.com/albums/n189/Maste … a/mario_001.png
So basically, the problem is when I get to the farthest door to the left on the first floor, I get the following 2 screens:
http://i112.photobucket.com/albums/n189/Maste … /dosbox_000.png
http://i112.photobucket.com/albums/n189/Maste … /dosbox_001.png
How do I fix this?
Steps I've tried so far:
1) use the original mount command for the CD as "mount e e:\emus\dosgames\mariom.iso -t cdrom" [without quotes or brackets] and I get the same farthest-to-the-left door crash in both .72 and .73.
2) Started a new game, went to that farthest door to the left first and it still crashes.
    dosbox.conf
    10 KiB
    189 downloads
Reply 2 of 6, by MasterO
Regardless of the settings you've suggested, every combination of those settings that I tried gives me the same error. It doesn't matter if I change the CPU Core, Machine type, or CPU Type.
Are there any other settings anyone can think of that might help?
Reply 4 of 6, by MasterO
Loadfix doesn't do anything, but thanks for the suggestion.
Anyway, after doing a little more testing, it seems I found the problem:
[original settings]
machine=svga_paradise
core=simple
cputype=386
xms=true
ems=true
umb=true
memsize=16
[new settings]
core=simple
cputype=386
xms=false
ems=true
umb=false
memsize=1
According to the game specs, Mario is Missing uses 512 K EMS Memory and 640 K RAM, so it just became a matter of changing the settings there. Apparently Mario is Missing doesn't like UMB or XMS... Well I feel stupid. 😅
Reply 5 of 6, by MiniMax
Rank Moderator
Moderator
core=simple is seldom used. Do you get crashes with core=auto, the default setting?
_________________
Reply 6 of 6, by MasterO
core=auto
cputype=auto
xms=false
ems=true
umb=false
memsize=16
No, core=auto and cputype=auto work properly here. Also, to clarify, after getting past that door on the first floor where the error occurs, I switched memsize back to 16 from the initial setting of 1 and the game runs fine so far. There are no other memory errors after that so far. If anything else happens, I'll post back.
