First post, by MadMonk
- Newbie
Playing Doom, Doom II, Heretic, etc. the mouse sensitivity is very low. I use DOSBox v. 0.73 Could anyone help?
increase it ?
there is a setting in the configuration of dosbox
Water flows down the stream
Thanks, but if I play on full screen the sensitivity is still same.
wrote:Playing Doom, Doom II, Heretic, etc. the mouse sensitivity is very low. I use DOSBox v. 0.73 Could anyone help?
In dosbox.conf you can set the mouse sensitivity using these settings under the SDL section
wrote:sensitivity = 1..1000 Mouse sensitivity. Default is 100. (since 0.??) […]
Mouse sensitivity.
Default is 100.
(since 0.??)
Additionally, why not just increase the mouse sensitivity in the game:
I increased the game's mouse sensitivity too but it's still quite low on full screen mode.
Maybe this is related? Mouse sensitivity changes between windowed and fullscreen
I've downloaded accidentally more DOSBox'es (when I got v. 73) like one and used the ''right'' one. Now I got the sensitivity higher.
