First post, by Vibhor
I am encountering this problem that whenever I remap controls in game and quit,the game resets the controls to default and also another problem that when I type anything on the map it doesn't display it whenever I re enter the auto map screen which relates to another problem that names of the shops,guilds or whatever doesn't get marked up on the auto map in towns.
I have used 0.73 and 0.74 version of Dosbox with the exactly same procedure for installation in the guide given by the site of Bethesda
The settings are the default except the fullsceen option and startup parameters
I have also modified the installation directory of the game.
Free space is 6 gigs+ and RAM is 1 gigs
VRAM is probably not important but still 256 megs
Is this intended for the game?
If this isn't then how do I fix it?
