First post, by RickSummon
I have created an ISO image of the data on CD 1 of The 7th Guest, and I have also created MP3 files of the two audio tracks. However, I can't get DOSBox 0.74 to play the intro CD audio by using a CUE sheet. I created it manually, so here's what I have:
FILE "CD1.iso" BINARY
TRACK 01 MODE1/2048
INDEX 01 00:00:00
FILE "02 - Theme Music.mp3" MP3
TRACK 02 AUDIO
INDEX 01 66:49:50
FILE "03 - Lead-Out.mp3" MP3
TRACK 03 AUDIO
INDEX 01 68:03:52
This does allow the data portion of the CD to be mounted correctly, but not the audio. How can I correct this?
(DOSBox has no problem playing the audio from the actual CD if that is mounted.)
[/code]
