Zombieville
Reply 21 of 27, by zelenog
Hi again,
I forgot how to properly type "freesize" command in DosBox.
Could you give me an example how to do it.
When I did it properly before, it game me "200 mb allocated" or something like that.
When I did it now, it gave me "illegal command" message.
Also, do I type "freesize" command before "mount c c:\" command?
Thanks in advance!
Reply 22 of 27, by DosFreak
mount c c:\DOSGAMES -freesize xxx
It's in the mysterious README file included with DOSBox.
Make your games work offline
Reply 23 of 27, by cuttock
Hi gang. While the game installed fine, and starts up fine, all the choices used in the "machine=xxx" area of the DosBox conf. file leads the game to play with a greenish hue. I then tried svga_et4000 and svga_et3000, and the colors of the intro and logo look fine, but when I begin the game, it crashes. I have noticed this "green hue" for some other games, as well. Is there a reason for this?
Reply 24 of 27, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
system?
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 26 of 27, by Dominus
DOSBox Moderator
Yes, problem on OSX with high color modes.
Reply 27 of 27, by cuttock
Thank you, Dominus. I resolved it by trying the game on VMWare fusion Winows XP/DOSBox 0.74. Worked fine.
I also tried a few other games, like Archimedian Dynasty, and got similar results. Thanks for this.
    180.18 KiB
