First post, by resin
- Newbie
Odd problem with Nascar Racing 2..
When I attempt to run the game, it says "Unable to find nascar2.exe in ' ' ." .. Or if trying to run setup it says "Unable to find setup.exe in ' ' ." .. On a fresh installation, this message does not come up and the game runs fine, but every time after that, the message does appear and the game won't run..
This happens with both the minimum and full installations. I've tried installing/uninstalling several times with the same result every time. I've seen this same issue mentioned in various forums, but there was never a solution.. Any idea what's going on here?
