First post, by ItsClipzZ
I trying to get a dos game called pizza tycoon working on my iPad. I downloaded DosPad (dosbox for iPad) . It would run the setup programme ( sound config ) but not the game , so I decided to emulate windows 95 in DosPad and then try to run the hand through windows. But I can't get any files from the iPad onto the c:\ in windows , I can get stuff to the c:\ of Dropbox , and windows let's me save files too it's c:\ do they must be getting stored somewhere , but for some reson it appears not to be the same place as dosboxs c:\
My questions: anyone know a way to get pizza tycoon working on iPad / dosbox / DosPad
Anyone know how to install stuff to a emulated windows on a iPad ?
Reply 1 of 18, by Jorpho
If this is a DOS game, what makes you think using Windows 95 would help? Can you perhaps give more details about what happens when you try to run the game?
If you are running Windows 95 in DOSBox, that means you are running it from a disk image, which means you need some way to put the files on the disk image. Because you set up Windows 95 yourself, right?
In any case, running Windows 95 in DOSBox isn't "supported" here and neither is DosPad. Does Pizza Tycoon not run under ordinary DOSBox on a desktop PC?
Reply 2 of 18, by ItsClipzZ
I have no pc , it broke and it's not worth fixing , can do most things with my pad or phone , the game works for others , and yes windows is on a image , and my thinking was mabye it would work because dos is built into windows ? I don't really kno just figured I'd try it .... Do you know any place where there's alot of DosPad users by any chance ? I really Want to play this game .... Well I really want to play the seccond one but it's not dos 🤣 , so now I really want to play this
Reply 3 of 18, by Jorpho
To be blunt, that is a pretty terrible idea, for a number of reasons.
If you want more help, then answer the question: What happens when you try to run the game in DOSBox without using a Windows 95 installation?
I suggest you Google. Better yet, why not just ask those "others" for whom the game works?
Reply 4 of 18, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
you *NEED* some kind of PC or some way to get the game on it... If your only way is to download the game you are on your own anyway...
Apart from that dospad works just like dosbox does.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 5 of 18, by ItsClipzZ
It does not crash it just won't load , when I try it says.
DoS/4gw protected run time version 1.95
Copyright......
And then a brief stall and my blinking blinker comes back and you can continue to type commands
Reply 6 of 18, by ItsClipzZ
I have the game , downloaded.. Just not on the windows image . It's in dosbox / DosPad though.
Reply 7 of 18, by Dominus
DOSBox Moderator
Correct me if I'm wrong but I don't think Pizza Tycoon was released as freeware. We do not help with pirated games.
Reply 8 of 18, by eL_PuSHeR
[Thread moved to DOSBox Games/Apps. Section]
Why not asking at the people who did the iPAD port?
And you better get the freeware version if available.
Reply 9 of 18, by ItsClipzZ
It's abandonware . Company shutdown and copywrite expired. And I owns this game years ago anyway.... And I did not ask the guys who made the port because this is where google took me
Reply 11 of 18, by ItsClipzZ
Well I downloaded lots of coppies trying to get this to work . Something like www.abandiononia.com was one , why do u all hate DosPad , it's not like your a company getting paid to provide support . Saying "we don't support DosPad" ignore the DosPad part then.
Reply 12 of 18, by Dominus
DOSBox Moderator
Actually I used dospad before and as I wrote it just works like dosbox for me. Much slower though...
We don't support pirated games. Abandonware does not make it legal.
Reply 14 of 18, by Jorpho
Copyright does not work that way.
ItsClipzZ wrote:
It does not crash it just won't load , when I try it says. […]
Copyright......
Might as well try to poke at this some more since the thread isn't locked yet.
What folders did you mount? What commands are you typing in after you start DOSBox?
Reply 15 of 18, by ItsClipzZ
Z:
Imgmount e var/mobile/documents/hdd/pizza
Boot e:
Or
Cd hdd\pizza
Pizza
Same result , I have read posts saying to mount to c:
But c is mounted to var/mobile/documents by default
Reply 16 of 18, by ItsClipzZ
Actually the mounted way tells me the image is read only and may cause problems , then says booting from a, eaven though I'm saying boot e , and what read only image ? I mounted a folder
Reply 17 of 18, by Dominus
DOSBox Moderator
You cannot imgmount a folder or you shouldn't, imgmount is for mounting a hard drive image.
The cd hdd/pizza
Pizza
Should work. You may try to move the folder one folder up so it is in var/mobile/documents
And do
cd pizza
Pizza
If that doesn't work, we can't help you because
- you are using a pirated copy
- you need to install the game correctly from its original cd
- there may be a problem with dospad in which case you need to ask litchie the author of dospad
Reply 18 of 18, by ItsClipzZ
Found problem , had to mount like this (as cd)
Mount e (folder) -t cdrom
