First post, by exofreeze
- Member
I've recently installed Star Crusader and the install process and game all seems to run fine. However when I attempt to use the flight simulator or start a mission the game crashes out saying:
Error reading header records from library speech.pak
I confirmed that the speech.pak file exists and is copied over during installation.
Using the debug version of dosbox I found it strange that it continually scrolls:
MISC:unsupported gate 2 mode 4 when selecting the options to launch.
However the debug version never seems to let me scroll back up (says to use the home & end keys). I tried dumping the results to a log file, but that slows things down so much that the game never launches.
I'm using 0.74 and my conf file is using the standard settings except for cycles which I have set to 9000.
