First post, by Don Meu
any suggestions??
Home of the Good Old Games
http://www.gog.com/
any suggestions??
http://www.gog.com/
Depending on your hardware and settings, cycles are probably set too high. Have you tried cyles=max instead of a fixed value?
"What's a paladin?!"
hi, with cycles=max DosBox even crashes at start!
now with these settings the music is ok at the main menu!, but the game crashes casually during training missions....
[sdl]
DOSBox.
fullscreen=true
fulldouble=false
fullresolution=desktop
windowresolution=original
output=Overlay
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
usescancodes=true
[dosbox]
language=
machine=svga_s3
captures=capture
memsize=16
[render]
frameskip=0
aspect=false
scaler=none
[cpu]
core=auto
cputype=auto
cycles=5000
cycleup=1000
cycledown=1000
[mixer]
nosound=false
rate=22050
blocksize=2048
prebuffer=80
[midi]
mpu401=intelligent
mididevice=default
midiconfig=
[sblaster]
sbtype=sb16
sbbase=220
irq=5
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplemu=default
oplrate=22050
[gus]
gus=false
gusrate=22050
gusbase=240
gusirq=5
gusdma=3
ultradir=C:\ULTRASND
[speaker]
pcspeaker=true
pcrate=22050
tandy=auto
tandyrate=22050
disney=true
[joystick]
joysticktype=auto
timed=false
autofire=false
swap34=false
buttonwrap=true
[serial]
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
xms=true
ems=true
umb=true
keyboardlayout=none
http://www.gog.com/
