First post, by quicksilver
Hi ,
I use a file-based database. And 4 People works with this Database. But the Problem is that thef files in the Dosbox doesnt get Locked. When i use the Database in a normal Dos commandline at a 32Bit PC it works. But when i Use the Database in a Dosbox Commandline i can Work but the File Lock doesnt work. Has anyone an Idea what i can do?
