Thanks to everyone for their work trying to get this game running. acutshall, did you ever get SS to work? I saw the "16-bit program not supported" error, but then I got windows 3.1 working using Dominus' instructions on this site.
I'm trying to make the game run in Windows 3.1 running in Dosbox on Mac OSX 10.8. I'm using the S3 video driver set to 256 colors small font. Once I got windows working, I tried running the Silent Steel setup file, and I got an error that I needed an MPEG driver and a WAV driver. I found vmpeg17 (http://www.filewatcher.com/m/vmpeg17.exe.553028-0.html) and Speakr from this website: http://ulihansen.kicks-ass.net/speaker/index2.htm.
Once I installed those, I stopped getting that error. Silent Steel installs fine, and when I run the program from windows 3, it starts to run, but the video does not play, and the sound is very very choppy and delayed. I can get the first and second set of choices to appear if I play with the options to skip the video, but the game is definitely unplayable.
Are there other drivers out there that might make the game work better? Am I mistaken that the drivers are the likely cause of these issues? If I tried to run the "steel.exe" file from the Silent Steel DVD, it says I don't have Video for Windows or the Indeo Codec. I found the Video for Windows driver and had it installed at one point, but have since deleted it. I couldn't find an Indeo Codec that I could install.
Thanks again, y'all. Any advice you can give will help.
