First post, by guyone
Just recently downloaded the 40 MB game Ascendancy and DOSBox.
When I try and run ASCEND.EXE this appears on the screen...
C:\ASCEND\ASCEND>ascend
DOS/4GW Protected Mode Run-time Version 1.97
Copyright (c) Rational Systems, Inc. 1990-1994
C:\ASCEND\ASCEND>_
SETSOUND.EXE also cannot find any audio drivers in the current directory and TDUJAM.EXE which I believe is how you install the game shows this...
Total free space for drive C = 110540800
Drive(s) available : C
Install to what drive :
Error : Unable to load program.
Error : File not found.
Strike a key...._
(Both quotes are EXACTLY as shown in DOSBox)
My question is what exactly do I have to do to make this run?(config editing?)
I've searched this forum and I just wanted to bring this thread back to life b/c it doesn't seem as if the problem has been solved.
It says on the DOSBox website Ascendancy is compatable so I'd like to know what I've done wrong.
I'm sure I left out important stuff so just ask and I'll reply ASAP
System Specs:
2100+ AMD Athalon
526 DDR RAM
Windows XP Prof.
80 Gig HD
