First post, by bryann5646
Is there a way I can config DOSBox 0.74 so that Ultima 6's music is off but the sound effects stay on? If so, how?
EDIT: Forgot to include which version I'm using.
Reply 1 of 2, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
In U6 choose SB as device then in the dosbox config disable SB emulation. AFAIK U6 uses the PC speaker as sfx output, so that might work.
Also, do you know Nuvie http://nuvie.sf.net ?
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
