Hawaii50 wrote:Thanks heaps rcblanke, the patch from The Patches Scrolls worked a treat, it just replaced the main executable and everything else worked, sound, music and in 16MB, now I just need to learn the actions, your a boss, cheers.
HI!
I too am trying to play this game with dosbox with pretty much the exact issue u had (except my version seems to be 1.00 because the cd is labeled PRAGEIV100). I downloaded the patch from patch scrolls and i unzipped it into my e:/dosbox (your c:/oldgames) but im not sure what you did after that to get it too work, when i run that exe i get a cannot find RM.DRV.
Some things ive tried:
Placing all cd files into my /dosbox folder
-removing Mr.DRV file from a folder and placing it in root of my /dosbox (this removed the initial error while running prage patch exe and changed it to cannot find INDEX)
-removed all files from subfolders and placed in my /dosbox root ( the prage patch exe now just shows a black screen)
Ive now removed everything from my e:/dosbox and just have the patch in it
any help would be very appreciated! š
