First post, by ETG-FatBoy
I've been trying to get Doom2 to run inside of DosBox since .61. And I've been getting this same error everytime. Back in the day I could remember what the cause was, but right now it's excaping me.
So, everytime I try running Doom2, I get this error and the game aborts:
S_Init: Setting up sound.
Attempt to set sfx volume at 248
What could the problem be? And am I forgetting somthing? Is there somthing in the default DosBox .62 setup that needs to be disabled for Doom2 to run? I will supply you with more info if requested.
