Thanks, guys... I'm clearly a lot more clueless than I thought. I've always used frontends in the past with DOSBOX, and I think I'm going to have to read up more to fully understand how it works. Meanwhile, yes, the game works, and it's on my external drive.
Ripsaw, the image file I've got is actually four files - ccd, cue, img, and sub. I haven't seen that before (all I've seen is iso and bin/cue), so I'm not sure how to mount that directly in DOSBOX, if it's possible at all. If not, I'll look online to see if there's a way to convert the files into a compatible format.
I hate to impose further on your expertise, but is there a way for me to set this all up so that a simple desktop icon will start the game in fullscreen? Like I said, I'm trying to make it as easy as possible for my wife and kids.
DosFreak - I wasn't trying to be contrary 😀 My external hard drive defaulted to G when I plugged it in, and I just thought it was easier to use A as its path since I use it so much. You mean I shouldn't generally use A or B for external hard drives? It hasn't caused a problem for me before, but I always wondered why the internal hard drive was C and it seemed that A and B were not utilized. I guess this is a relic from when A and B were for floppy drives?
