First post, by kip89
It starts plays the first "video" with the car driving and i press enter and the it shuts down. i saw a post about having to press enter at the right time, so i tried that and it still didn't work. I have a Pentium 4-2.8Ghz windows xp sp2, 1gig dual channel ram and a Nvidia Fx(i believe) 5200 128mb. Plz i need help i really want to play.
Reply 1 of 4, by laxdragon
I still have this old PC Gamer CD where they put a bunch of full DOS games on it. Alone in the Dark was included in that set. This version does not exibit this problem. No needing to press enter or anything.
Reply 2 of 4, by kip89
I have it on floppy format, its four floppies and if i run it without dosbox it has the same problem.
Reply 4 of 4, by kip89
sry i forgot to check back. If i run it without dosbox it just freezs while the car is driving in the first scene,and if i let the "video" run in dosbox it goes until the stairs into i geuss the attac then goes to the command prompt. if i click on the fitd.exe it pops up and then closes.
