First post, by Draygon
Ok, I have a program that I need to run for work, I have the program installed and it says
"The system file is not Suitable for runningMS-DOS and Microsoft Windows Applications."
So I downloaded DOSBox to emulate and hopefully run the program. My problem is now that I am in DOSBox and I am in the correct directory but when I tell it to execute the file I see in the backround window
"Write 0 to rom at ..."
ANd nothing happens, so how can I get this to execute and run. Maybe Im not typing the execute command correctly, I had thought that it is just the .exe name in this instance its QL. So it would be just QL <enter>.
Help plz.
