First post, by DoomEad
I have the game "Blood" v1.0 and have it installed on another partition from Windows called D:\ I have installed DOSBox OK and is sucessfully running. I can access the "Blood" directory on the D:\ partition from within DOSBox but after the "Blood" does the main scrolling up of info about loading it's tiles and other things I am then asked to centre the gamepad button, then d-pad up to upper corner and press a button etc and then the screen goes blank and the cdrom drawer spits out so I press the cdrom eject button to close the drawer and again it spits the drawer out again? Any ideas?
Also, do you know if DOSBox will run "Blood"'s expansion pack "Cryptic Passage"? I bought "Cryptic Passage" a few years ago and never been able to play it as I get the message "Runtime error 200 at 04CE:0091" when I try to install it. It's been claimed that my computer is too fast to run "CP" hence the error message. Yet "CP" requires only the same specs as "Blood" and "Blood" runs OK?
Intel Pentium 3 800Mhz
Windows 98SE
GeForce2 GTS V770 32Mb
512Mb RAM
SoundBlaster 1024 LIVE value player
