First post, by SARA
CAN ANYBODY HELP ME?? IM TRYING TO PLAY FRACAS FROM GECKOSOFT ON DOSBOX IN WINDOWS VISTA AND IT DOESNT work all i get is a black screen.. how can i make it work? i used to love to play this game and now i have the full version.... 😢
Reply 1 of 15, by Vince.Bloodworks
Hi SARA,
I don't know if it's the same version as you got it
( I've downloaded it from here http://www.dosgames.com/dl.php?filename=http: … soft/FRACAS.zip ).
When I tried to run this game with the MegaBuild 6, i've got an error with the DOS4GW. Then I tried to run the game in Dosbox 0.70 and it worked!
In this Dosbox, the memory amount and the cpu-core are:
memsize=16
core=normal
Try to use these settings, maybe it'll work for you =) ...
Good luck
Vince
Reply 2 of 15, by Miki Maus
Works fine here on Windows XP in DOSBox 0.74 with default settings.
Reply 3 of 15, by Vince.Bloodworks
Hmm I always get this error while trying to run the game (in Dosbox 0.73 and 0.74):
DOS/4GW Fatal Error: Can't initialize loader[1] -- LINEXE_LOADER
I've installed Dosbox 0.74 again on a different drive, only mounted the directory and tried to start the game but it's the same error.
I'm using Windows XP Pro with SP3.
But I only wanted to help SARA and I don't play this game anyway(at the moment .. maybe later ^^) so that's not a problem =D
Reply 4 of 15, by SARA
i KNOW IT WORKS ON XP thats why i said WINDOWS VISTA... 😖
Reply 5 of 15, by SARA
THANK YOU SO MUCH I'VE ALREADY PLAYED THIS GAME ON WINDOWS XP ON MY OLD PC, I WANTED TO PLAY ON VISTA AND I CANT DO IT WITH DOSBOX... 😢 although on xp i could only play the demo version, the full version wont work to with dosbox... 🙁 thanks anyway 😀
Reply 6 of 15, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
If it worked in Dosbox on XP, it works in Dosbox on Vista. If it doesn't the user Sara is doing something different. Maybe installing it again helps... But make sure you fix your caps lock key, could be this is creating errors...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 7 of 15, by SARA
i tried to use dosbox 0.65 cause on the dosbox site says that its compatible with fracas, but it also doesnt work..
Reply 8 of 15, by SARA
sorry for caps.. 😊
Reply 9 of 15, by sliderider
I just downloaded it and ran it with DosBox .74 under Windows 7 and it worked fine for me.
Reply 10 of 15, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The game appears to work OK with default settings. Have other games displayed something in DOSBox on your Vista system? Try changing the output setting in your .conf to ddraw, overlay, or opengl.
Reply 11 of 15, by SARA
thanks it is already working!! 😊 😀
Reply 13 of 15, by SARA
i wasnt opening the file in the proper way, it needed to be unziped from winrar properly.. and it works fine now in dosbox. my bad. Sorry and thank you 😀
Reply 14 of 15, by pamgb1963
Hi Sara! Do you are able to use a joystick with Fracas? I can't play Fracas with a joystick, the game doesn't acknowledge its presence. I have Windows XP SP3. 😢
Reply 15 of 15, by Jorpho
Are you able to use your joystick with any other game in DOSBox?
