First post, by theozzman
Ok first off its probably important that i say i downloaded crusader no regret from an abandonware site, so anyways i try to fire it up and it doesnt work so i download DOSBox the first problem i had was when the game was loading and it said it was missing a mouse.shp file so i went on the internet and downloaded one from a site (probably not specifically for crusader) then i go to fire it up agin and just as the little loading bar was reaching the end another error came up and said "out of memory in file GRAPH\VPORT.c, line 103." i went to see if there was a file like that in my crusader folder but there wasnt. so in conclusion i dont know wheather or not i am missing a file or what but i need help
thank you
Reply 1 of 9, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
you need the specific Crusader file. That's the problem with abandonware sites, you are never sure if it is complete.
Reply 2 of 9, by mirekluza
DOSBox Moderator
VPORT.C is an original source code file in C which was compiled to something else (usually <something>.EXE).
This is an error report which programmers made for themselves.... Probably caused by using bad MOUSE.SHP...
Mirek
Reply 3 of 9, by theozzman
can someone put their mouse.shp for no regret on here
Reply 4 of 9, by HunterZ
I think that would be against the rules and the moderators would probably remove it even if someone did post it...
Reply 5 of 9, by MiniMax
Rank Moderator
Moderator
They could... And as soon as I see an illegal upload, the file will be deleted, and this thread will be CLOSED.
_________________
Reply 6 of 9, by HunterZ
I was going to mention the possibility of thread-locking as well, but I didn't want to back-seat moderate or anything 😉
Reply 7 of 9, by theozzman
well then could ya at least send it to no they can't
Reply 8 of 9, by theozzman
OK then can you post a site where i can download it from
Reply 9 of 9, by DosFreak
NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NONO NO NO NO NO NO NO NO NO NONO NO NO NO NO NO NO NO NO NONO NO NO NO NO NO NO NO NO NONO NO NO NO NO NO NO NO NO NONO NO NO NO NO NO NO NO NO NONO NO NO NO NO NO NO NO NO NONO NO NO NO NO NO NO NO NO NONO NO NO NO NO NO NO NO NO NONO NO NO NO NO NO NO NO NO NONO NO NO NO NO NO NO NO NO NONO NO NO NO NO NO NO NO NO NONO NO NO NO NO NO NO NO NO NONO NO NO NO NO NO NO NO NO NONO NO NO NO NO NO NO NO NO NO
Thread closed.
Make your games work offline
