First post, by ischo74
could you give me your hand ?
I've tried to install one of my favorite , strike commander ,on my laptop.
After disabling EMS , ems=false , the install begun. I can remember
the installation procedure . there was some process , like.. generating MAP after copying files from floppys. actually, problems happened at this point.
dosbox window was frozen ... dosbox gave me just black screen.. and
I checked cpu usage.. and found DosBox used 98% of cpu.
how can I figure it out ?
Reply 1 of 3, by wd
Rank DOSBox Author
DOSBox Author
If you have access to a windows computer, you can
try the attached executable.
Use DLLs from the official dosbox release or some
others, any missing DLLs should be downloadable
from the internet somewhere.
Do NOT use ems=false with this build.
wd
    dosbox_sc_win32exec.rar
    316.9 KiB
    192 downloads
