Regarding Duke3d and Plutonium
Having problems with a specific game or application? Post your problems here!
Postby Quake161 » 2018-8-10 @ 05:07
Yes yes, another one. I've went through all the forums here looking for a work around and haven't found a proper solution.
Lets first get these out of the way:
-No access to a VPC
-Running windows 7
-Running Dosbox 0.74
-Own both the original Duke3d disc and the Plutonium disc.
Once I have installed Duke in dosbox, I proceeded to try the Plutonium disc and update the game.
It stated that "The patch had failed, please reinstall" message. I then found the PPack15 on 3drealms' site. Tried again, same result.
Came onto the forum to try the timestamp issue. I did get the computer and dosbox to install all the files using the "1996 13:40" time and date.
Verified it though both dosbox and the windows explorer.
Tried installing the patch, Same result.
At this point I'm just disappointed. Is there something I'm missing/applying wrong?
Quake161
Re: Regarding Duke3d and Plutonium
Postby Rawit » 2018-8-10 @ 06:53
I assume you used the "1996-04-19 13:30:00" date for the timestamp issue? Because you wrote "1996 13:40".
User avatar
Rawit
Postby Quake161 » 2018-8-10 @ 07:23
Yes. Sorry, had my son crawling on me.
Quake161
Postby Rawit » 2018-8-10 @ 08:26
Quake161 wrote:Yes. Sorry, had my son crawling on me.
:happy:
You could try the Daum DOSBox version which seems to have timestamp support.
User avatar
Rawit
Postby gdjacobs » 2018-8-12 @ 01:14
Please be aware that Daum is old, unsupported, and has lots of bugs. YMMV.
User avatar
gdjacobs
Postby collector » 2018-8-12 @ 07:37
Usually not a good idea to recommend Daum. It is broken and as noted, it is completely unsupported, so if there are issues you are on your own.
User avatar
collector
Postby buckeye » 2018-8-15 @ 15:06
I waded thru this headache myself and said heck with it and ordered the Atomic edition (has all updates/add ons built in) off ebay, worked fine with my XP rig running Dosbox/D-fend Reloaded.
Foxconn Q45M E8400 Core2 Duo 2GB DDR2 800 160GB BFG Geforce 7950GT 512MB 500W XP SP2
Asus P3B-F P3 850 512MB 40GB Hercules 3D Prophet II 64MB Voodoo2 SLI Aureal Vortex 2 400W 98SE
User avatar
buckeye
Return to DOSBox Games/Apps
Who is online
