First post, by lfl_038
I have made a software under Turbo Pascal 4 which was running on MSDOS 6.2.
This software uses specials characters in the filename of the file used to save the configuration.
The filename is chr(255)+"FONC-DE.F"+chr(255).
The file provided could not be read under DosBox 0.74 so I tried to generate a new one under DosBox 0.74 without any success (same error).
I have read all DosBox documentation available but I did not find any answer.
Could you please confirm that DosBox does not accept special characters in filenames ?
If you want to test, a download zip file is available here or attached.
Thanks in advance,
Best regards.
The attachment Appr871Dos.zip is no longer available
Reply 2 of 4, by lfl_038
I just check the code, in fact the character used is not char(255) but is char(127).
It seems this character is not working in DosBox as, when I updated the code, removing these characters, the program is working (see attached).
So, can you confirm that char(127) is not allowed in a filename in DosBox ?
Thanks in advance,
Best regards.
The attachment Appr871DosBox.zip is no longer available
Reply 3 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
Yep, 127 is not our allowed list at the moment. Do you need to be on ?
Water flows down the stream
Reply 4 of 4, by lfl_038
Thanks for your reply.
If you can add it in the allowed list, it could be great.
If, not, this is not critical as I could build a special version using file without this character.
Best regards.
