First post, by Neville
- Oldbie
Hello all.
I've been following the guide to install Windows 3.11 under DOSBox, and everything -save sound, I didn't go that far- seems to work fine.
Problem? I want MORE. I've been searching here and there and got several of my old applications ready to work, such as Word 6.0 or Excel 5. The problem is that those need SHARE.EXE running in order to work (although the install process works flawlessly). I've tried to use the SHARE.EXE from my old MS-DOS 6.22 disks, but DOSBox complains it is the wrong version and won't run it.
My questions are:
1) Is there any DOSBox command or setting that substitutes SHARE.EXE?
2) If there's not, what can I do to make my own SHARE.EXE to work?
3) And, if that's impossible, what other versions of the file will work under DOSBox and where can I get them?
Thank you for your attention and for susch a kickass program, really.
