First post, by Gwhite
I'm trying to use DOSBox to rescue some old engineering software. By using the Windows CVS build, most things seem to work pretty well. One thing I've discovered is that there are some quirks that appear when I try to plot anything. The system uses VGA graphics, and long straight lines have regularly spaced gaps that are probably only one pixel long. In addition, the text characters (which are draw with 1 pixel lines) appear to be missing the right hand column of pixels. For example, the last vertical stroke of "M" and "W" aren't drawn, and the right most tips of "X" are missing.
I'm running the latest CVS build, but the problem also exists in 0.63. The problem occurs on a high end Dell, and an IBM laptop, so I don't think it's a hardware issue. Both systems are running Windows XP Pro. The problem occurs whether the program is running in a window or full screen.
I've created a small stand-alone executable that illustrates the problem, in case anyone wants to check it out.:
http://users.rcn.com/gwhite/APL/DBoxPlot.zip
I seached the archives & came up empty, so I don't know if this is a known issue or not. It doesn't prevent anything from running, but I thought folks should know about it (if they don't already).
Thanks!
