First post, by enex
I'm trying to get Daggerfall working in DOSBox 0.65. I'm running the game through the command fall.exe z.cfg and all I get is a black screen, and I recieve errors in the console if I run the game in a window:
Illegal read from 37eeabe9, CS:IP 560c:37e94b28
Illegal read from 37eeabea, CS:IP 560c:37e94b2a
Illegal read from 37eeabeb, CS:IP 560c:37e94b2a
Illegal read from 37eeabec, CS:IP 560c:37e94b2c
Illegal read from 37eeabed, CS:IP 560c:37e94b2c
Illegal read from 37eeabee, CS:IP 560c:37e94b2e
Illegal read from 37eeabef, CS:IP 560c:37e94b2e
I've made sure that all of the files in my Daggerfall directory are not write-protected (I copied an installation over from a disc). I've also tried all of the graphics outputs and I've disabled sound. Also, "full" is the only CPU setting that works, "dynamic" and "normal" crash DOSBox immediately when I open the game.
Here is my dosbox.conf:
fullscreen=true
fulldouble=true
fullfixed=false
fullresolution=1024x768
output=overlay
hwscale=1.00
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
language=
machine=vga
captures=capture
memsize=60
frameskip=0
aspect=false
scaler=none
core=fulll
cycles=18000
cycleup=500
cycledown=20
nosound=true
rate=22050
blocksize=2048
prebuffer=10
mpu401=false
intelligent=true
device=default
config=
type=none
base=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=22050
gus=none
rate=22050
base=240
irq1=5
irq2=5
dma1=3
dma2=3
ultradir=C:\ULTRASND
pcspeaker=none
pcrate=22050
tandyrate=22050
disney=true
xms=true
ems=true
Here's my system:
Kubuntu 5.10
AMD 64 3000+
NVidia 6600 AGP 128 MB
ASRock 939DualSATA2
Turtle Beach Riviera
1 GB RAM
Some Maxtor 200 GB IDE drive
I had tried DOSBox 0.63 previously and had similar problems, except I got multicolor snow when I ran the game and Illegal opcode messages in the console window. :x
Has anyone had a similar experience or knows what is going on?
