Blood problems
First post, by Eviladam
I have downloaded the latest version of dosbox
and when I try to startup blood and I get this
"Dos\4gw fatal error (1004): syntax is Dos4gw<executable.xxx>"
Reply 1 of 14, by franpa
did you run blood.exe in dosbox or dos4gw.exe?
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 2 of 14, by Eviladam
I used dos4gw
Reply 3 of 14, by franpa
so is problem fixed? if not then use blood.exe to play the game and setup.exe to setup the sound and resoloution etc.
my website
Reply 4 of 14, by Eviladam
Well I recently downloaded a frontend for it and It wont work either.
Reply 5 of 14, by Eviladam
and I tried blood exe too
Reply 6 of 14, by wd
Rank DOSBox Author
DOSBox Author
Does it display the message above when running blood.exe??
Must be a corrupt installation then.
Reply 7 of 14, by franpa
make sure you setup the sound etc. before playing.... run setup.exe when in dosbox to set the sound.
my website
Reply 8 of 14, by Eviladam
Well I just fixed the problem by telling it the sound card is "none"
because my sound cards irq is freeking 19 and blood only goes high as 15
so I could play it but I only can listen to music as I play.
Reply 10 of 14, by franpa
try irq 5 and/or 1rq 7 for soundblaster 16 (a330 mpu-401 for music)
if it doesnt work post back...
my website
Reply 11 of 14, by Eviladam
The sound card I have is a soundblaster live 24 bit will that work?
Reply 12 of 14, by DosFreak
DOS games in XP don't care what kind of sound card you have. For DOS games Windows XP emulates a SoundBlaster card. If you configure your DOS games to use any IRQ other than 5 then they will not work.
Make your games work offline
Reply 13 of 14, by Eviladam
Thanks for the info,Caleb's voice scared my dog Right out of the room 😁 as in it works!
Reply 14 of 14, by franpa
to clarify... windows xp simulates an soundblaster for dosgames.
and dosbox emulates a soundblaster 16 for dosgames.
my website
