First post, by rick2230
I can get the game up and running and play right through. However, every time I or the computer moves a piece the line "os_size changed" appears starting at the top left of the play screen and repeats down the page with each move. Sometimes up to 5 & 6 lines at a time. This of course obliterates a portion of the left side and the pieces on that side. Very annoying!!!
    131.77 KiB
Reply 1 of 2, by nybble
rick2230 I am getting the exact same problem in BC4000. Originally I thought it was tied to the fact that I was running multiple virtual machines at the same time. This turned out not to be the case. I am going to continue to play around with the app to see if I can determine why this is occuring. BC4000 was always a fun game, I never played it for chess though, I always played it for the capture animations 😎
Never eat shellfish during months other than those ending in the letter 'r'.
Reply 2 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
should be possible to find
game probably uses an int10 function to display the text.
Water flows down the stream
