Jetfighter
Reply 21 of 25, by wd
Rank DOSBox Author
DOSBox Author
Well more a sort of protection for the executable. Most often you find
exe-packing/protection when there's some copy protection as well, but
maybe for that game they only wanted to avoid people mess around
with the executable.
Reply 23 of 25, by wd
Rank DOSBox Author
DOSBox Author
I didn't make the sourcecode public. It's nothing complicated, just modified
the normal core to fetch a bunch of opcodes instead of only the next one.
Seems to emulate the prefetch queue quite accurately i think.
Attached a build from the current CVS sources with prefetch queue
emulation, if you really need the sources for some reason, please
send a PM or something.
    cvsbuild65_pq.rar
    477.36 KiB
    894 downloads
Reply 24 of 25, by rjsummer
I'm not really familiar with DOS box, I actuially built a 386 recently to play these old games on. Jetfighter I (on a single floppy) works great on the old machine. If you need any files from the distribution disk, I have it and the manuals. Faster machines, I think, regardless of the DOS box cause runtime errors. That's my experience anyway for what its worth.
Reply 25 of 25, by Norton Commander
I can confirm that Jetfighter (the original release) has no copy protection. When I bought it a while back I copied the disks and installed/played the game from the copies so whatever protection exists is probably to prevent modification of the executable.
