Ah. As for the text being unreadable, it shows up [the best way to describe it] broken. The menu text for arcade and all that is a little fuzzy. I tried playing arcade mode, and tried selecting kung-fu man. i waited 5 minutes, and i got nothing, despite the fact I pressed the selection button multiple times.
Now, for the dynamic core and auto cycles, can I adjust that? [only thing I know how to speed up in Dosbox is frames per second...] And lastly, I tried adding a character in to my select [I've done it before, so I really doubt I messed this part up], and he doesn't show up on the character select screen. If it helps, his name is DragonClaw...
