First post, by Sektor88
Alright, all of my directories are correct. when i enter the command to run the game, i get the error message: "Load error: No DPMI - Get csdpmi*b.zip". So, two questions here. 1. where do I find it, and 2, what exactly does it do?
Reply 1 of 17, by wd
Rank DOSBox Author
DOSBox Author
You can either
a) search the forum
b) search for the files in the net
Reply 2 of 17, by Sektor88
Well, i found the files and they're in the correct directory. Another problem, though. When I start the game [windowed or not], some text in-game comes up [I believe it's things about the game/story etc], and at the bottom says [from what i can see] press *some key* to continue. So, i'mn pressing every key on my keyboard, something works, it moves to the character select screen, and it just seems to be going quite slow. Anyway, I don't mind the speed, I'm more interested in the text. Is there anything that can be done to fix that?
Reply 3 of 17, by wd
Rank DOSBox Author
DOSBox Author
Says "press f1" for me, which works fine. Then there's some menu.
Speed is fine with the dynamic core and auto cycles.
In what way is the text unreadable? Is the text in the menu ok?
Reply 4 of 17, by Sektor88
Ah. As for the text being unreadable, it shows up [the best way to describe it] broken. The menu text for arcade and all that is a little fuzzy. I tried playing arcade mode, and tried selecting kung-fu man. i waited 5 minutes, and i got nothing, despite the fact I pressed the selection button multiple times.
Now, for the dynamic core and auto cycles, can I adjust that? [only thing I know how to speed up in Dosbox is frames per second...] And lastly, I tried adding a character in to my select [I've done it before, so I really doubt I messed this part up], and he doesn't show up on the character select screen. If it helps, his name is DragonClaw...
Reply 6 of 17, by Sektor88
Sir, yes sir! [thanks!] and now I loaded up mugen and it's giving me a blank window where the game should be.. X_X
Reply 7 of 17, by wd
Rank DOSBox Author
DOSBox Author
What dosbox version are you using? What OS?
Reply 8 of 17, by Sektor88
Wait! It's giving me the game...the same way as it was before, and now no characters in the select screen... X_X Despite the fact I added that one guy in and took out the default one... >_>
Reply 9 of 17, by Sektor88
Oh, I'm using Dosbox 0.65, and running mac OS Tiger.
Reply 10 of 17, by wd
Rank DOSBox Author
DOSBox Author
Maybe you could see if the game you have works under Windows/Linux,
could be that it's some Mac specific bug.
Reply 11 of 17, by Sektor88
Well, there is a windows and linux version for it, so yeah, maybe the DOS one is just being weird...
Reply 12 of 17, by wd
Rank DOSBox Author
DOSBox Author
Hm no, i thought to try the windows/linux version of dosbox with your
version of the game. As mine seems to work fine (dos version of Mugen).
Reply 13 of 17, by Sektor88
Ah. Okay. I'll give that a try then. 😁
Reply 14 of 17, by Sektor88
Hm. Clicked on the gentoo linux link for the download, and it redirected me to the Gentoo linux homepage... So I guess it's somewhere on there? X_X
Reply 15 of 17, by wd
Rank DOSBox Author
DOSBox Author
Don't they have a package grabbing system? "emerge dosbox" or something
Reply 16 of 17, by Sektor88
I'm not sure. I'm taking a look now...
Reply 17 of 17, by Sektor88
hmm...this is very..odd.. X_X
