First post, by ecco4502
please, it cant read my fonts
Needs help in more ways then one
Reply 1 of 13, by wd
Rank DOSBox Author
DOSBox Author
Well maybe you can formulate your problem more precisely.
Like what you mean with video mode switching, what fonts
you want it to read etc.
Reply 2 of 13, by ecco4502
i need it to go below 800X600 please
Reply 3 of 13, by wd
Rank DOSBox Author
DOSBox Author
The game or dosbox?
Reply 4 of 13, by ecco4502
dosbox needs to go to video mode but cant, i have xp and the res. only goes to 800X 600 as its lowest
Reply 5 of 13, by wd
Rank DOSBox Author
DOSBox Author
So you start dosbox and it tells you that it can't switch to resolution xy
or does it tell that only when you start a game?
And what's the resolution/colour depth of your desktop?
Reply 6 of 13, by ecco4502
my resolution currently is 1024X768 and when i command dosbox to start a game, it sayd it needs to switch to video mode, which is 640X480, im trying to run mugen dbz if that helps
Reply 7 of 13, by wd
Rank DOSBox Author
DOSBox Author
Be sure that you're using dosbox 0.65.
Maybe you can post a screenshot of the error (png preferred).
Reply 8 of 13, by ecco4502
how do i check?
Reply 9 of 13, by wd
Rank DOSBox Author
DOSBox Author
The top line of the dosbox window should read like "DOSBox 0.65".
If you're unsure download it again from the homepage (http://dosbox sf.net)
and install it.
Reply 10 of 13, by ecco4502
lemme check
Reply 11 of 13, by ecco4502
yeah it is 😅 😢 but i got it elsewhere lemme try there
Reply 12 of 13, by wd
Rank DOSBox Author
DOSBox Author
Maybe somebody has that game and can check if it works for them or not.
Reply 13 of 13, by ecco4502
not working, but hold on
