First post, by red_avatar
Today, I was recommending some games to a friend, and realised I hadn't tried Pizza Tycoon on DOSBOX yet, so I went ahead and got it off an abandonware site. But after I set up the sound in the install menu and entered the game, I still didn't get any sound. Sound nor music.
After trying varying settings (considering music only had one option, and no setting, there's little to do wrong really) I decided to dig out my CD version of the game, in case the game I had downloaded was somehow damaged. After installing the game, I get the same problem: no sound or music. I remember that this game had music playing when the game was started, yet nothing in DOSBOX.
Does anyone know the reason for this? Or could anyone confirm this? In case it's a specific DOSBOX setting that causes this (I have tried with several versions, but still, they all use the same settings).
Reply 1 of 7, by SysGOD
yup, pizza tycoon uses a sound blaster FM driver that dont like dosbox.
you can test it by running the sound.com from the sound folder manually.
it gives you an error like: fm feature not available on the card.
well, the only workaround i found (after hours of modifying and testing) is to reduce cpu cycles to something like 3000.
after the sound driver is loadet you can increse it back to normal values.
hope this help
Reply 2 of 7, by wd
Rank DOSBox Author
DOSBox Author
Reduce cycles to 3000? Well 3000 is the default, and it's not an arbitrarily
chosen value.
Reply 3 of 7, by SysGOD
🤣 yeah, i know. the last time i used default dosbox settings was after the release of 0.65 i think.
sry for that...
Reply 4 of 7, by red_avatar
Actually, "auto" is default in all CVS versions I download now. But I'll try that, thanks.
EDIT: okay, not only does "auto" have to be turned off, you also have to turn max off. With "auto" core still on, it wouldn't work either - setting it to dynamic works. Also, 8000 cycles works too.
One odd thing is that it uses low DMA for its DMA setting, although it lets you chose from 1 to 7, which usually means HDMA.
Reply 5 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
odd. there is no max setting combined with auto in our code.
auto could work as it keeps the cycles at 3000 unless the game switches to protected mode.
Water flows down the stream
Reply 6 of 7, by red_avatar
I'm using ykhwong's build.
Reply 7 of 7, by wd
Rank DOSBox Author
DOSBox Author
Well then, it works in clean cvs builds, right out of the box.
