First post, by Jiri
I have sound glitches in the game Harvester. Bad results are in DOSBox, Windows XP or Windows XP with VDMSound. Sound setup utility with sound test can run without the game so I attached it if anyone want to test it.
    SETSOUND.zip
    385.67 KiB
    258 downloads
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
in the setup:
sbpro:220 7 1
sb16 7 5
the sound goes from right to left and it sounds quite good at my place with sb16
Water flows down the stream
Reply 2 of 2, by Jiri
Thanks for reply. I recorded sounds from setsound and the game. You may notice glitches at the beggining and end of setsound file. In the game is slight static sound that does not belong there.
    harvest(game).mp3
    83.81 KiB
    327 downloads
    harvest(setsoundSB16).mp3
    33 KiB
    325 downloads
