STTNG: A Final Unity Installation Guide for DosBox
Reply 100 of 112, by V00D00
HunterZ wrote:
There's a fix for that too. Edit your dosbox config to use one of the output= options other than the default output=surface.
It's great, it's just great. Like the feeling I had, when System Shock was finally running.
Though the game lags sometimes I couldn't stand to play the first mission and by the way: I messed it totally up!
But it makes nearly as much fun as the 25th Anniversary and Judgement Rites, which is a pretty good sign of quality.
The sound stumbles, when I move the cursor - especially at the egdes. Is there a fix for that too?
    dosbox-0.73.conf.txt
    9.92 KiB
    405 downloads
Reply 103 of 112, by swaaye
FYI, I've been playing this game again and have found that the space combat is unstable with the dynamic core. Switch over to normal core and all is fine.
Reply 104 of 112, by VAUXHALLBOB
was really looking forward to playing this game however i cannot get it to play. Keep receiving following error message-
fatal error. could not find resource file - check CDpath in sttng.ini.
My settings are
; Star Trek: The Next Generation, IBM Version.
Audio=SB16
Port=0x220
IRQ=0x7
DMA=0x5
Video=HI16
DPixel=ON
Path=C:/STFU/
CD=C:/STTNG1
Sound=ON
Music=ON
Voices=ON
Movies=ON
Advice=0
Dialogs=OFF
VolSound=0x7FFF
VolMusic=0x7FFF
UniVESA=ON
very frustrating as all i want to do is play this old classic 😢
Reply 106 of 112, by rftl
Hi i have a Problem with dos32a in A Final Unity.
I don't knowh how to activate dos32a.
It has no dos4/gw file so i used the sh.exe
The Problem
sb.exe sttng.exe
Application Type: Standard DOS Executable
So where is DOS4/GW?
Ok now i tried.
/R and /U but they don't work (ok no suprise wothout dos4/gw)
And even /B didn't work (yeah a long shot i know).
How do i use dos32a on STTNG:AFU
Oh by the way i tried it in Dos Box 0.73 and 0.74
Ah and one other thing.
Why dosen't the game start when the univesa otion is on?
After the Spectrum Holobyte Copyrigth i get only a "Can't open value".
These question are out of curiosity.
The Game itself runs fine without any modification.
Reply 110 of 112, by docdj
I too am having the DOSDigiIinit problem. I went looking for your link to the STTNG.OVL file and I can't seem to find it. Could you re-post the link or tell me where I can get the file? I am running DOSBOX 0.74. 😢
DocDJ
Reply 112 of 112, by docdj
Tried cycles=4000. I get the Star Trek logo and then it fails back to the dosbox prompt. Still using original code from the CD. 😢
I am not using DOS32a. Vanilla DOSBOX 0.74, vanilla AFU from the boxed CD.
I have tried every SB setting (but get no sound). I have tried every monitor-type. Same failure or no video at all, depending on type tested.
DocDJ
