Genewars
Reply 20 of 31, by ErikGG
How did you mount your drives?
Erik.
Read the new FAQ.doc
Reply 21 of 31, by OSH
mount c "d:\gry\test\genewars"
mount y "d:\emulatory\ultrasnd"
C:
cd/
GW.EXE
Reply 22 of 31, by MiniMax
Rank Moderator
Moderator
And how did you mount it when you installed the game?
_________________
Reply 23 of 31, by OSH
I'm using D.O.G. I've only mounted C: drive, that's everything... haven't installed this game, just copied...I don't remember where I found this game, maybe on H.O.T.U...
Reply 24 of 31, by ErikGG
I see you mounted this :
It should be d:\gry\test\ for C:\ (mmm, I could put in a warning about this in D.O.G.)
Games don't like being in the root of a drive.
If this doesn't work check and see if a cfg file or any other setup/options file kan be edited with notepad in the games root directroy. If so check and see if there is an pathname in this file. Correct this one to the "DOSBox" internal path, C:\genewars\.
Hope this helps.
Erik.
Reply 25 of 31, by OSH
That doesn't help 😕
But I have one question: How big is this game after installation? Mine has 38 MB...
Reply 26 of 31, by wd
Rank DOSBox Author
DOSBox Author
You replied to MiniMax's question that you only mount C and didn't install it,
now you're talking about stuff during installation. If you don't post the
complete information about the steps you take, this discussion does not
make any sense.
Reply 27 of 31, by OSH
wd...When I write "installation" I mean "copying". I've downloaded INSTALLED (I think so, but I'm not sure) version. In other posts I've read, this game can be up to 98 MB disk space...
Reply 28 of 31, by wd
Rank DOSBox Author
DOSBox Author
I've downloaded
Then ask the people where you downloaded that.
Reply 29 of 31, by OSH
Very funny, indeed.
Ok. I've solved my problem. I've edited file called "config.ini" and give right paths. In "CD" section and "InstallDrive" section must be the same path given - the path to installed game. After that, a game works. I have a ripped version and I haven't music. But a game works...
Reply 30 of 31, by ADDiCT
wd wasn't trying to be funny - you're the "funny" guy here. Your "solution" is a very good example why many users on VOGONS, including myself, are reluctant to give support for "Abandonware" games. If you were trying to install the game from original media, you wouldn't have had the problem in the first place.
Reply 31 of 31, by red_avatar
I agree. IF you want to use abandonware games, which most of us do, at least make sure you know how to handle ripped games. There's nothing worse than spending ages trying to discover a problem which is caused by a bad rip instead of Dosbox.
