MPC Battle Chess - No Music
Reply 20 of 22, by giblet_squasher
robertmo wrote:
sorry but have you checked dosbox manual for different cdrom settings? they are designed specially and only for cd audio problems
Yes I tried all of them and nothing worked. Thanks.
Reply 21 of 22, by giblet_squasher
bloodbat wrote:
Maybe your CD doesn't have those audio tracks...hm hm...Otherwise...Make the image properly?
Yeah. I think it's just a bad disc.
Reply 22 of 22, by rolloLG
Gamecollector wrote on 2011-08-05, 07:02:
DOS version is working perfectly for me with the DOSBox. Sbtype=sb16, irq=7, dma=1 in dosbox.conf. And "SBPro" when installing cdchess. CD mount string was "mount d k:\ -t cdrom".
It looks like I don't have [MCI]CD Audio driver in my WfW 3.11 in DOSBox. So - this is the cause for "no music" in MPCChess. When I find my WfW floppies - I check this again.
giblet_squasher - check the TOC of the CD - it must have 1 data track and 21 CDA tracks.
Today I wanted to install MPC Battle Chess under Win3.11/DOSBox and faced same issue: error at launch reporting CD Music driver problem.
Solved it installing additional CD Audio driver (MCICDA.DRV) under Win3.11:
I found "MCICDA.DR_" file in Win3.11 setup disks, just renamed it "MCICDA.DRV" and it worked and was flawlessly installed by Win3.11.
MPC Battle Chess now works perfectly fine including music and battle audio, thanks to this helpful thread.
